A partner has attempted to join to BVM over the Routing Protocol Interface, but its address type is not supported by this instance of BVM. Only a BGP instance using VPN routes will be accepted.
Check the configuration of each master entity.
Error
A partner has attempted to join to BVM over the Routing Protocol Interface, but its address type is not supported by this instance of BVM VRID = %p1% BVM supports IPv4 VPN routes? = %p2% BVM supports IPv6 VPN routes? = %p3% Address type = %p4% Address subtype = %p5%
| Name | Type |
| p1 | sInt32 |
| p2 | sInt |
| p3 | sInt |
| p4 | uInt8 |
| p5 | uInt8 |
